Hi all, just a quick question.
I am running Uccnc version 2.111 on a Minix neo computer.
When I load an average size g-code file , when jogging the machine I can see the DRO lagging.
But the bigger problem is when I run the ATC it will slightly mess up the timing of the solenoid firing which will cause the tool to knock while clamping(All air pressures are regulated correctly) - if I change tools before loading an average sized file it will run perfectly and the DRO will not hang up.
I'm just a bit confused as this PC is slightly above Uccnc recommended specs I would think it would run files larger than what I am running.
The file I'm running was toolpathed in Vectric Aspire using the Uccnc ATC PP. It is a simple profile cut of 300mm x 150mm work area with about 25 peck drills doing a pass of 0.5mm.
So maybe this is a bit more than my PC can handle?
Any suggestions will be appreciated thanks!
