Im using a keyboard emulator which correctly outputs ascii characters. As a test they show up properly in the MDI text field.
I am trying to call function code 220,221 and 222 which calls the axis select for an MPG handwheel encoder.
The hotkeys on the host laptop do select the chosen MPG axis. Why wont the emulated keystrokes change the MPG axis selection as expected?
Makes no difference if the emulator uses ascii chaacters, hex, or letter numbers.
Any ideas?
