When I search the forum for 'tachometer' I get only 10 hits so I guess this is a little discussed topic, and maybe what I want isn't possible. It appears that UCCNC only accepts encoder signals to read actual spindle speed, but my spindle motor has a tachometer output rather than encoders. In fact the mill was equipped with a DC brushed servo motor with a Servo Dynamics servo drive for the spindle motor and control and I use PWM to the drive for controlling the spindle speed. The tachometer wire from the motor is fed into the drive and in fact requires it to function (I suppose this is common but I don't have much experience with servo drives). Anyway, the motor nameplate states output of 7V/1,000 RPM, I assume but haven't checked that is DC output signal. So is there a way to convert that for input into UCCNC, maybe some auxiliary piece of hardware like possibly an analog to digital converter?
