Hi all,
First of all, thanks for reading my post.
Second, I am not an expert and much more close to a junior/rookie in CNC domain so, sorry in advance if my question sounds obvious for some of you.
Third, I am converting a SIEG SX3 to CNC and I am setting-up an UC300ETH + UB1 boards and I am using UCCNC software.
I would like to have an external 24V/20mA lamp/LED lighting each time an axis moves.
To to so, my idea is to do 'something' to link the, for instance, XS+ port to and output port like Y301.
I don't know if that's doable in terms of wiring but, if so, I anticipate that I will have to do a macro or UCCNC config to connect the dots and make sure that each time an axis moves, according output port will send a 24V signal.
Is that realistic ?
What should be the plan B to reach my goal ?
Thanks in advance
Philippe
