Multiple Profiles
Posted: Tue Dec 20, 2016 4:48 am
I am in the process of a machine conversion. I am working on understanding some of the software features so I can make decisions on what operator interface would be convenient in hardware and which can be done in software. The machine is a Shopmaster MillTurn which is a combination machine. I am thinking I will have one profile for mill and one profile for lathe. There is a relay that directs the output of the spindle VFD to either the mill motor or the lathe motor. I can put a switch on the front panel to select. However, I would like to know if there is a way in the profile to configure a output so the state of an output would be high in one profile and low in another. That way, the appropriate spindle would automatically be selected depending on which profile you run.
I see in the manual the Output Trigger capabilities, but don't fully grasp how I can use it in this situation.
I do see some neat application of the Input Trigger capability for some convenient feature like cycle start,... Not being a machinist,.... are there some high value hardware inputs that you might suggest? I'd like to figure all this out before I engrave a panel ;?)
