24vdc power supply size?
Postby spillage » Sat Jan 23, 2021 3:28 pm
I realize it’s going to depend on what your driving with it (relays etc), but generally for a basic setup with limit switches, what’s the recommendation for size?
Bryan
“Simplicity is the ultimate sophistication“ Leonardo Da Vinci
spillage
Re: 24vdc power supply size?
Postby cncdrive » Sun Jan 24, 2021 6:29 pm
A 25W should do, it gives you a bit over 1Amps. It is not enough only if you using lots of high power relays, those could sink lots of current, but for a standard setup 1Amp should be enough.
