Setup probe screen
Re: Setup probe screen
Postby dezsoe » Sun Oct 18, 2020 7:56 pm
1.2049 had no probe screen, it was released in 1.2108. Do you start with the profile that you use or do you load a profile after startup?
Postby dezsoe » Sun Oct 18, 2020 8:49 pm
See my post here. The probe screen doesn't support loading a profile.
Postby Delco » Mon Oct 19, 2020 10:30 am
There is also a option to save setting on exit in setup too I believe
Delco
Postby dezsoe » Mon Oct 19, 2020 11:37 am
Yes, there are for some parameters. All others are always saved on exit. But! When the program starts, the probing plugin reads all parameters from the current profile. Then you change the profile, but the probing plugin will not load the parameters again, because it reads only on startup. All the parameters are saved to the second loaded profile (that is active on exit), but on startup it does not read this profile.
