explanation on different coordinates and implementation
Postby patgabatch » Wed Oct 07, 2020 8:14 am
Hello everyone, after having without difficulty and with your help succeeded in doing the necessary so that my machine can work, I find myself facing another problem which is the understanding of the machine or work coordinates and of course their implementation. I launched a program in order to adjust my work plane in relation to the tool and during the maneuver, my Z axis goes way too low and would damage the assembly if I did not work blank. I think I deduced that it came from the machine coordinates but I don't know how I was able to integrate them into uccnc and of course modify them. the surfacing then seems to work properly. Can you explain to me the difference between the different contact details and how I can remedy my problem. I specify that I am in France and therefore the translation is done by google, imagine when I have to do a search on the site.
Thanking you in advance
Patrick
patgabatch
Re: explanation on different coordinates and implementation
Postby patgabatch » Wed Oct 07, 2020 8:46 am
I specify that when I do a go to home my coordinates are X = 0, Y = 0 and Z = 100
patgabatch
Postby dezsoe » Wed Oct 07, 2020 11:44 am
Hello Patrick,
Try to read this article and if you have more questions then ask here.
Postby patgabatch » Wed Oct 07, 2020 3:11 pm
thank you for answering and after reading the article, indeed I begin to understand a little but unfortunately that does not solve my problem. My cnc is equipped with a limit switch. when I run a home all, my axes go home, and on my desk I read X = 0, Y = 0 and Z = 100. when I go to the offsets page, I read the following machine coordinates X = 0, Y = 0 and Z = 100.
1 I am unable to know how I was able to create these coordinates.
The following problem follows, when I do the planimetry of my table and after leveling my tool, the Z goes too low in it would damage the tool and the table if I was not working in blank.
how to modify the machine coordinates of the Z so that it is at 0 (high position) instead of 100. or did I make an error when creating my drawing on fusion360?
patgabatch
Postby dezsoe » Wed Oct 07, 2020 7:41 pm
The machine coordinates can be set only by homing the machine. When the homing of an axis is finished and the "Auto set" is checked then the "Write offset on homing" value is written to the machine coordinate. Check your Z axis setup page.
Postby patgabatch » Thu Oct 08, 2020 10:00 am
hello and thank you for your answers, your help is invaluable and i was able to make the changes as mentioned in your answer. everything works fine. Another big thank you for us beginners
patgabatch
Postby andrewbishop66 » Thu Oct 08, 2020 7:33 pm
Patric check the value on
Configeration page
Z Axis
Write offset on homing (units ) i would guess yours is set to 100
Hope that helps
Thanks Andrew
andrewbishop66
Postby patgabatch » Sun Oct 11, 2020 6:13 pm
hello, indeed I corrected the data on the Z page by zeroing the data and everything works correctly. I was able to run a first G code, everything is OK
thanks again
patgabatch
