Going from mach3 to UCCNC
Postby hautamak » Tue Apr 21, 2020 5:44 am
Hello!
I have built plywood router for machining wood and aluminium, and it have been working good, except couple of issues.
1. It's losing steps and the problem is chinese usb motion controller, or TB6600, both are going to be replaced. I'm buying axbb-e controller with UCCNC
and leadshine EM806.
2. Lasering is kinda tricky right now.. I have arduino to translate XY speed to laser pwm power, but still it lags some amount between first moves and when laser turns on. I was wondering if Axbb-e and UCCNC have full support for XY speed related to laser vector cutting speed. And I mean real, no lag syncronisation. raster engraving seems to work ok with UCCNC based on videos I have seen online.
Also, my last laser was bad and diode burned out. I was thinking if I wired it right, AC->PSU 12v->laser diode arduino pwm->laser 5v pwm input. Could it be problem that my 24v psu and 5v psu are grounded to same?
Is there somethinge else I have to consider?'
Bit of messy post..
hautamak
Re: Going from mach3 to UCCNC
Postby Tweakie.CNC » Tue May 19, 2020 8:22 am
I know you will find that changing to UCCNC for laser raster and vector working is the best move you could possibly make. Some of the laser engravings I made during my UCCNC testing are shown here; viewtopic.php?f=5&t=2115
Once you have it all up and running, I guarantee, you will not look back.
Tweakie.
Tweakie.CNC
Postby Robertspark » Tue May 19, 2020 9:00 am
download and install the development version of UCCNC available here (it will run in demo [no motion output] till you buy a licence + cncdrive motion controller (AXBB-E)
viewtopic.php?f=2&t=240#p18850
have a look in the documentation folder at the manual (have a really good read of the manual)
an extract of M10/M11 for laser control is below.
there is also a plugin for laser etching / engraving which is detailed in the manual too (it does not produce gcode but directly controls the laser and axis movement in a linear / grid pattern).
there are also various youtube clips you can trawl through too
https://www.google.com/search?q=uccnc+l ... 24&bih=529
