Probe setup
Probe setup
Postby voyager1972 » Thu Apr 16, 2020 9:01 pm
hi
i am using the uc300eth lpt with the ucbb-1 bob,,
i would greatful for some help with the probe setup and wiring with uccnc,,,,,i have upgraded the chinese router which previously had a xhc mkiv motion controlller.
voyager1972
Re: Probe setup
Postby voyager1972 » Sun Apr 19, 2020 11:12 am
the probe is a basic 2 wire type,,,one wire is going to the top of the gantry where i can plug the probe into and place below the spindel,,then remove when zeroed,,,,,this wire is also connected to the machine frame,and back to the o voltage on the bob,,,,does the other wire need to be connected to a 5v supply then to an input??
voyager1972
Re: Probe setup
Postby ger21 » Sun Apr 19, 2020 11:43 am
What model probe is it?
Re: Probe setup
Postby voyager1972 » Sun Apr 19, 2020 11:57 am
one of thoses cheap two wire probes on ebay at,,,,,,,im using the uc30eth with the ucbb-1 bob & uccnc
voyager1972
Re: Probe setup
Postby eabrust » Sun Apr 19, 2020 10:32 pm
Voyager,
The wire that comes from the alligator clip should go to a ground/com on your board, and the wire that comes from the touch plate puck should go to input pin of your choice.
In UCCNC, when you setup the probe input for the pin/port you selected, set it for Active low (check the box). Verify by looking at the probe LED on 'Diag.' page and touching the clip to the puck pad. LED should only be on when clip is touching pad.
If you ever setup a normally closed type touch probe later on a second probe input (or wire it so you have to swap them to the same input), it would be wired similarly, but you would set it for Active high (don't check box for active low).
Re: Probe setup
Postby voyager1972 » Mon Apr 20, 2020 6:57 am
Thanks for the reply,,,, does the wire goto the + or - side of the input,,, do I have to take power to the other input side?
voyager1972
Re: Probe setup
Postby ger21 » Mon Apr 20, 2020 10:39 am
Wire as shown on page 13 of the UCBB manual. Either of the two ways will work.
Re: Probe setup
Postby eabrust » Mon Apr 20, 2020 10:45 am
I probably should have known more about the UBB-1 before I replied, its a little different than I thought.
Wire it per the ' NO switch ' method per the manual. I'd still put the clip end on the 0v end of power, and put the puck wire into the ' -ve ' side of input. Connect '+ve' side of input to +V.
Looking at how this is done on the UBB, it likely means the touch plate will then behave like an 'active high' input instead of 'active low' when you setup the pin info in UCCNC (and vice verso for a Normally closed type touch probe also).
good luck
Re: Probe setup
Postby voyager1972 » Wed Apr 22, 2020 9:26 am
Thanks Eric,,,,, I had a broken wire which was stopping the circuit making the connection,,,,
voyager1972
Re: Probe setup
Postby voyager1972 » Wed Apr 22, 2020 7:09 pm
the red wire was broken off the connection,,,,,,,,,every day is a school day
voyager1972
