SWAP AXIS w/Spindle
SWAP AXIS w/Spindle
Postby Spuds » Tue Apr 07, 2020 11:27 am
Has, or will this be implemented ?
viewtopic.php?f=2&t=1372&p=10241&hilit=swap+axis#p10241
dezsoe wrote:SwapAxis cannot swap the spindle with an axis. The spindle homing feature would be a nice thing, but now it's not implemented.
I am mounting a live tool on a lathe and need the spindle to act as a regular spindle and also a rotary axis.
Which is the easier way ?
I think Mach3 can swap Axis/Spindle ?
Spuds
Re: SWAP AXIS w/Spindle
Postby Spuds » Wed Apr 08, 2020 1:34 pm
viewtopic.php?f=2&t=1372&p=10241&hilit=swap+axis#p10250
Thee appears to be some missing posts here.
Could someone please fill in the blanks for me ?
Spuds
Postby dezsoe » Thu Apr 09, 2020 9:51 am
As I remember, the same pins were set as e.g. C axis and step/dir spindle. When the spindle is on then you must not use the C axis and vice versa. With this configuration you can home the spindle as an axis.
Postby Spuds » Thu Apr 09, 2020 7:46 pm
OK, thank you.
I will experiment with it.
I really don't need to HOME the axis to a sensor.
I think I can just set it to program 0.000 within the swap macro.
Will need to play with it.
Thanks again,
Spuds
