macro led numbers
macro led numbers
Postby jcoldon » Thu Mar 05, 2020 11:03 pm
I trying to use probe input 1 and probe 2 in a macro
can some one tell me what led number I have port 1 pin 6 port 2 for port 1 it there some place this information is
I add port 2 as soon as I can make port 1 work
I am trying to make a macro for a plasma using the axbb controller probe 1 ohmic then probe 2 be slide
I want probe 1 to have a different offset setting then probe 2 this way if ohmic misses the slide switch still set cut setting.
is there a plasma macro out there ready made I can just change around I not a programmer
I know this can be dun I just have no idea how to do the macro
jcoldon
Re: macro led numbers
Postby dezsoe » Thu Mar 05, 2020 11:23 pm
In the UCCNC\Documentation folder you have an LEDs_by_number.htm file. Port 1 pin 6 is LED 6, port 2 pin 6 is LED 76.
The pins are called OutputPT<port>PN<pin> even if they are input pins.
The AXBB has 6 inputs (1..6) on port 2 and 5 inputs (10..13 and 15) on port 3.
