Trigger output when in camera capture page
Postby renotec » Sun Feb 02, 2020 1:56 pm
Is possible to trigger an output (UC300ETH-5LPT) when I'm in TOOLS -> CAMERA page (V 1.2112) ?
I have bright LED light around the camera, I like to turn it off when using camera because that bright light interfere badly (hard to see captured image).
Thank you in advance.
renotec
Re: Trigger output when in camera capture page
Postby cncdrive » Sun Feb 02, 2020 5:00 pm
Yes, ofcourse, you can use an output trigger. You can also use a button number 20000 to 21999 in the output trigger and then you can add an onscreen button. You can also use the hotkeys... so you have several options to do that.
Postby renotec » Sun Feb 02, 2020 10:48 pm
I don't want to add any button, all I want is ;
As soon as when I click "CAMERA" button in "TOOLS" page, trigger one of output pin of my UC300ETH-5LPT.
Hope UCCNC has LED code for "Camera In Use"
renotec
Postby dezsoe » Sun Feb 02, 2020 10:59 pm
See the documentation: LEDs_by_number.htm. LED 264 - Cameracaptureon - On when the camera is activated.
Postby renotec » Tue Feb 04, 2020 12:03 am
Thanks, works perfectly !
* missing 264 - 269 in output trigger "Set"
renotec
Postby renotec » Tue Feb 04, 2020 12:16 am
Well... only problem is LED264 stay high even I'm not in TOOLS -> CAMERA page, I have to manually turn "Capture" off when exit.
renotec
