Uccnc spindle setup
Uccnc spindle setup
Postby Stock3000gt » Sat Jan 11, 2020 5:33 pm
How would I setup the spindle settings in uccnc? The following pics are how I have it setup currently but can get it to trigger th vfd.
Stock3000gt
Re: Uccnc spindle setup
Postby Stock3000gt » Sat Jan 11, 2020 5:43 pm
Vfd wiring
Stock3000gt
Postby Stock3000gt » Sat Jan 11, 2020 5:44 pm
Uccnc setting
Stock3000gt
Postby Stock3000gt » Sat Jan 11, 2020 5:47 pm
Uccnc settings
Stock3000gt
Postby Stock3000gt » Sat Jan 11, 2020 5:49 pm
Vfd manual wiring
Stock3000gt
Postby ger21 » Sat Jan 11, 2020 7:28 pm
1) What are all the white wires on the VFD connected to?
2) Where do you have the red, white, and blue wires connected. You typically would only use 1 or 2, connected to DI1 and DI2. You don't seem to have these wired to the correct terminals.
3) You don't have any port and pin numbers assigned to M3 or M4. These are what start and stop the spindle.
So, it looks like you have both wiring issues, and UCCNC setting issues.
Postby Stock3000gt » Sat Jan 11, 2020 8:49 pm
The red white and blue aren't hooked up at the moment do to the last picture I posted doesn't show them hooked up but an easy fix. What would I need to input in UCCnc? The white wires are connected to an internal relay if I am reading the diagram on the last pic correctly.
Stock3000gt
Postby Tweakie.CNC » Sun Jan 12, 2020 7:04 am
Just looking at your pictures...
You appear to have the VFD wired so that +12V is directly shorted to GND by the fault relay (WHT and BLK wires).
Your VFD wiring diagram shows a bulb (or similar resistance) in that circuit preventing the short circuit.
Tweakie.
Tweakie.CNC
Postby Stock3000gt » Sun Jan 12, 2020 12:26 pm
I know have the red on com blue on d1 and white on d1. Removed the white and black wires. Does that seem right?
Stock3000gt
Postby Stock3000gt » Sat Jan 18, 2020 12:51 pm
Had to add a relay to turn on the spindle got that working but cant seem to get uccnc to send less than 10v to the vfd. Any help you can give is appreciated.
Stock3000gt
