probe guage height limits
Postby Delco » Sat Dec 21, 2019 4:22 am
I came across a issue today when using my fixed touch probe and my vice , the distance between the vice parallels and my touch probe is 52.45mm , when I go into the simple probe screen and try and set the probe guage height it will not allow me to enter a number larger than 50 ?
Is there a setting somewhere I can change it or is it hard coded in ?
Delco
Re: probe guage height limits
Postby dezsoe » Sat Dec 21, 2019 8:54 am
That is limited to -50..50 only in the screenset, so you can change it with the screen editor.
Postby Delco » Sun Dec 22, 2019 7:05 am
Thanks will give it a try and see if I can work out how to edit it.
Delco
Postby dezsoe » Sun Dec 22, 2019 8:32 am
Press Edit screen on General settings, minimize the editor window, while pressing Shift select the probe screen, restore editor window, click the field, change maxvalue, press Apply, select File tab in editor window, press Save screenset, close editor window. Ready.
Postby Delco » Tue Dec 24, 2019 9:20 am
Delco
Users browsing this forum: Bing [Bot] and 32 guests
