Spindle Speed ->UC400 ->Triple Beast ->Huanyang HY02D223D
Postby mgolec » Fri Dec 06, 2019 6:48 pm
Hi!
Anyone here which is using the same config for milling.
I don't know about the settings in uccnc and at the inverter.
Since the update of uccnc this spindle speed via pwm (0-10v at the FU) does not work.
When I set 10000rpm in uccnc its is faster than 15000rpm… Its working in the wrong direction!
I know about the Plugin, but my VFD does not have RS485 because its a one with only one control terminal.
Maybe anyone can help me please? Import from working MACH3 settings does not work.
Greets Markus
mgolec
Re: Spindle Speed ->UC400 ->Triple Beast ->Huanyang HY02D223
Postby mgolec » Mon Dec 09, 2019 5:05 pm
Bump!
No one with huanyang inverter without rs485 here?
Greets Markus
mgolec
Postby MattTheNoob » Fri Dec 13, 2019 2:32 am
Is your drive looking for 0-10v analog or PWM? Those are two different things.
If your controller is putting out one, but the drive is expecting the other, it won't work. There are boards that will convert one to the other, and they aren't expensive.
MattTheNoob
Bostomatic 405 with updated controls... now entering Rev.2
UC300eth-5lpt, ModBus talking to Click PLC, Arduino Gecko servo monitor
Total UC noob.
MattTheNoob
