I've got my probing setup with a simple block and spring clamp to the tool. I then touch the tool to the block and get position which I use as the tool offset. It works fine.
My question is surrounding grounding and my machine. I have a bridgeport mill.
I had to put Kapton tape on the back side of my touch block to make it work.
Thus this limits my ability to probe a bore or a side of the actual work piece, does anyone have any suggestions on how I can keep my circuit from closing when my tool touches anypart of the mill ?
