Been doing some testing on UCCNC today concerning cycle times.
And i am having a problem finding any correlation between my estimated times coming from Aspire and the real time taken on the machine.
Take this part as an example:-
Est Cycle time from Cad/Cam = 13.55 mins
Actual cycle time on machine = 38.5 mins
I have tried loosening the cv parameters by as much as 3 times the original amounts but it does not help much.
MCE 0.1
MLE 0.1
MLAL 1
MLUL 2
to
MCE 0.3
MLE 0.3
MLAL 1
MLUL 2
The feed rate in the program is set to 3000mm/min but it seems to never get above 1200 to 1300 (Bit difficult to see the spikes in feed rate).
I have my accel set to 250mm min.
I have tried it at 750mm min (even though my machine would not actually run at this accel)but this still only reduces the cycle time to 27 mins
I came across one of batwells video's on youtube which shows the same problem.
He has his feed set to 6000mm/min but most of the time it is cutting below 2000mm/min
https://www.youtube.com/watch?v=9OhaldtZbMQ
Tried to attach the file but it is over 2mb.
