probing for plasma
probing for plasma
Postby jcoldon » Wed Oct 30, 2019 6:07 pm
i use the m31 is there a way to add a number to the macro to over come a switch offset for the torch slide i use it in the post procesor now want to change it to the macro
also is there a way to add 2 probes were probe 1 would be an ohmic . and probe 2 would be a torch slide
so if the ohmic mises the second probe switch would set the cut height or if i just turn off the ohmic use the switch
jcoldon
Users browsing this forum: Bing [Bot] and 14 guests
