Can't get past demo mode
Postby gk285267 » Wed Oct 02, 2019 8:29 pm
When I start UCCNC I get the same demo screen, to select which demo controller I have. I pasted the license in the UCCNC folder and verified it is there. The UC300ETH-5LPT is powered up. The green led is bright. the ethernet cable is firmly plugged into the computer and the controller. The cable between Port 1 and the breakout box is firmly connected. What am I missing? Thank you
gk285267
Re: Can't get past demo mode
Postby cncdrive » Wed Oct 02, 2019 8:38 pm
Do you get a "no valid license key found" message on the software startup?
If yes then it is a license key issue.
If no then it has nothing to do with the license key, but the software does not see your controller and cannot communicate with it.
This is likely because the network is not setup correctly.
Did you setup the network (IP/subnet mask) as described in details in the UC300ETH-5LPT manual?
If so then what does the UCx00 utility tool says when you testing the connection?
Postby gk285267 » Wed Oct 02, 2019 9:22 pm
Right on. Pages 8 & 9 of the UC300ETH etc User's guide is very clear on setting up the IP Address and subnet mask. Done. And now UCCNC loads perfectly. Thank you so much.
gk285267
Postby wiidtick763 » Sat Feb 29, 2020 9:51 pm
I am having the same problem. Standalone laptop windows 7, no internet connection, running uccnc with uc100. worked great yesterday. Only enters demo mode. green and blue lights on uc100. Tried switching usb cables, no change.
wiidtick763
Users browsing this forum: No registered users and 31 guests
