by Fabmonster » Fri Sep 20, 2019 6:49 pm
Hello I’m new to this community and CNC for that matter. I recently destroyed a parallel port breakout board that came with my machine as a result I decided to go with the AXBB motion controller . I’ve read and reread both manuals for this piece and still have not been able to get movement. my ethernet connection is set up properly and tests well . With the AXBBb powered down I’m able to move all of the axis when I power up they won’t budge so signal is getting to the motors obviously not the right signals feel like I have the drivers wired correctly in common anode but I’m a little confused as th whether I have the enable wired correctly. My drivers are different then most everyone else’s that I’ve seen online and in forums. Mine only have four inputs the H/D( which I have no clue what this is ) and GRD have no connection I believe they’re grounded together internally but I’m not sure. I have not seen any examples on how to wire my type of drivers anywhere and it’s not for a lack of looking . Also have another strange occurrence happening, I’m getting inaccurate readings on my diagnostics tab , in fact , if I unplug everything from the AXBB it still shows lots of inputs and outputs in both red and green. that’s clearly not right what could possibly be the cause of that ? I’m having a hard enough time as it is I don’t need any exotic problems to just confuse me more any help would be greatly appreciated
- Attachments
- My driver
