Probing says the machine was not yet homed!
Postby zymurgy42 » Sat Sep 14, 2019 7:36 am
Version 1.2111
UC100
A Axis slaved to X, all axis have sensors for homing.
Can run machine OK. When I home ALL, I get the GREEN indicator on each axis.
Yet when I try to probe (I am trying to understand this added feature), I get the message "the machine was not yet homed!"
Gordon.
zymurgy42
Re: Probing says the machine was not yet homed!
Postby 1JUMPER10 » Sat Sep 14, 2019 12:14 pm
Same thing happened to me. My A axis is slaved to my Y axis. To fix it, after homing my Y axis, when the Y axis is at the home position, hit the home button for the A axis. UCCNC will then see
That all enabled axis' are homed and probing will work.
1JUMPER10
Postby cncdrive » Sat Sep 14, 2019 1:18 pm
Check your homing sequence and remove any axis which is not in use.
Postby zymurgy42 » Sun Sep 15, 2019 5:33 am
cncdrive wrote:Check your homing sequence and remove any axis which is not in use.
Homing sequence has laways been 1.Z, 2.X and then 3.Y.
For 4, 5 and 6 NONE.
Learning from 1Jumper10, I selected HOME A, indicator turned GREEN and Probing was successful.
Something needs my Slave axis home LED to be active.
G.
zymurgy42
Postby dezsoe » Sun Sep 15, 2019 9:18 pm
No problem with the homing sequence. When I wrote the probe screen I didn't think of slaved axes. If an axis is slave then only the master's home LED will go on, so I had to make some changes to the check of the home state. The next version will work well with slaved axes.
Postby zymurgy42 » Sun Sep 22, 2019 5:18 am
Cool Bananas :)
zymurgy42
