Where to find "Labels_by_number.htm" ?
Postby GaryLa » Thu Aug 22, 2019 2:32 pm
I just upgraded to 1.2111 and inside the user manual, in section 2.2.3 there's a reference to a file "Labels_by_number.htm".
I do not have this file in my Documentation directory.
As a side note, I also noticed that the Current Hi/Low pin is no longer on the "I/O Setup" tab as it was with 1.2049.
The user manual shows it on page 27, but I do not have the same screen.
How can I use this functionality with version 1.2111?
GaryLa
Re: Where to find "Labels_by_number.htm" ?
Postby Vmax549 » Thu Aug 22, 2019 2:39 pm
The Latest Test version current Hi_Lo setup is in teh Axis config section for EACH axis. AND yes you can set it to teh same pin/port for each axis so you ONLY use 1 output.
(;-) TP
Vmax549
Postby Vmax549 » Thu Aug 22, 2019 2:53 pm
Check teh Fields_ByNumber HTM that might be what you are looking for.
(;-) TP
Vmax549
Postby GaryLa » Thu Aug 22, 2019 2:56 pm
Thank you very much. Very helpful !!!!!!!!
I also just noticed the prior user manual is still present in the directory, even though all other remnants of that version seem to be gone. I think I was occasionally crossing between the new and old manual by accident.
GaryLa
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
