Aspire laser post processor
Posted:
Wed Apr 10, 2019 9:39 am
by Delco
I am having some issues setting up UCCNC for my laser.
I have it working at present by using a M3S# speed command but wanted to try and use the M10 command.
The post processor I found outputs a M10S# but this does not seem to work I have the laser port enabled as well as the same port enabled for the spindle PWM
looking at the aspire website it seems to want a M10Q# is this correct ? And the # to be between 0 and 255 ?
I have laser on port 17 PWM and power relay on port14
Also is there a slider to change the output of the laser like there is for feed and speed ?
Re: Aspire laser post processor
Posted:
Wed Apr 10, 2019 12:13 pm
The format is M10Q... (Q->0 to 255), the Q could not be S, because S is the spindle speed command, so Q is the parameter of M10.
You have to enable the M3 also, because it is a safety enable signal for the laser.
So, enable M3 first and then you can do M10 and M11.
Posted:
Fri May 10, 2019 9:37 am
by marteng
I too currently own Aspire (version 4.5) and am in the process of building a CNC Router with CO2 laser incorporated. I have been using Aspire for my router since the beginning and, I have found it superior to other softwares on the market. I would like to use Aspire to produce laser cutting / engraving / rastering paths as well, but have been told that I would need a post processor for the laser.
Delco, have you managed to fix the problem with your and if so, could you kindly advise how did you go around it?
Regards
Marteng
Posted:
Mon May 13, 2019 9:07 am
by Delco
Yes I got mine working fine I have attached the file I am using
Posted:
Mon May 13, 2019 9:49 am
I think you forgot to attach the file.
Posted:
Tue May 14, 2019 12:10 am
by Delco
Oh errors because of extension .pp and didnt load. change .txt to .pp after loading
Posted:
Mon Aug 23, 2021 1:49 pm
by zapbrannigan
Delco wrote:Oh errors because of extension .pp and didnt load. change .txt to .pp after loading
Works for me in 2021.
Thank you.
Posted:
Mon Oct 31, 2022 7:20 am
by marteng
Delco wrote:Yes I got mine working fine I have attached the file I am using
Hi Delco, thanks for the update.
Regards Marteng
