Unknown g-code
Unknown g-code
Postby Mark81 » Fri Feb 22, 2019 5:41 pm
I did a search in the forum but I wasn't able to find an answer.
I'm new to this controller and I need to migrate all my old files to the new machine.
When loading a file I often receive the warning that it contains "unknown g-code". I'm aware in the manual there is the list of supported g-codes, but I think it would be much much easier if the message dialog will list the bogus ones and the related line number. Otherwise it is time-consuming and error prone to manually scroll the whole file to catch a g-code which is not available in the list.
Any suggestion is welcome!
Mark81
Re: Unknown g-code
Postby ger21 » Fri Feb 22, 2019 6:41 pm
1) You can set UCCNC to ignore them. This may or may not work for you, depending on what the codes are.
2) You can change the color of the non recognized codes, so they are easy to see in the display.
