Spindle motor to servo
Posted: Sun Aug 26, 2018 11:03 am
Ok, non uccnc question, but I know I'll get an honest answer here.
Looking at changing a b14 flange motor with a 14mm motor shaft from a 1/2hp 3 phase 230v to a servo motor.
Why, it's a lathe spindle motor, and need to do some internal spline profile work , so was wondering at the viability of changing to a servo motor (or hybrid stepper with closed loop encoder drive)
The question is, should I be looking at 1hp servo motors?
The lathe spindle is suppose to be able to driven from 50rpm up to 2500rpm and I'd like to keep the same range (I'm not sure the 2500rpm from the lathe manufacturer is correct and not sales bull, given its a 4pole motor and it's pulley driven with a ~1.8:1 ratio)
The plan is to get something with a similar mounting flange size as I don't want to have to change too much on the lathe.
Never used servos before
