JOG Pendant
Re: JOG Pendant
Postby RWC » Tue Apr 09, 2019 10:07 pm
Very cool ... good job !
Now ... (I just gotta see that macro :D ) :?:
:D
Thanks TP,
Russ
:mrgreen:
RWC
Re: JOG Pendant
Postby Vmax549 » Tue Apr 09, 2019 10:46 pm
Hi Russ , It would be easy to TEST the stability of the analog value in UCCNC.
Start with a 5v signal and add a resistor to bring it down to what ever voltage level you want to test at.
Then create a macro loop to monitor teh analog value over time. You could write teh values to a log file so that you could SEE any diviation and what level of diviations might occur over time.
You could also use 2 channels to show what teh original volt level is (5v) and another channel to show the test volt level (1v or 1/2 volt)
THEN you would know for sure (;-) UCCNC is VERY handy for things like this.
OR maybe someone could write a simple plotting routine plugin to show it as a plot over time.
IF you bring out the values as a CSV file then you could import it into a spreadsheet and plot it out from there.
(;-) TP
Vmax549
Re: JOG Pendant
Postby RWC » Fri Apr 12, 2019 7:03 pm
I can also monitor the analog inputs at the bottom rt. of the diagnostic page.
The manual doesn't describe it though. (everything except) :?
Using four 1K resistors in series I get the following 5 digit representations for each position. (only using 1 channel.)
The highest being direct to 5V. (they are not in any particular order in the pic. )
What does this 5 digit value actually represent ? I was expecting the actual voltage. :roll:
The values only waiver by about +/- 15 ..... then settle in and become a bit more steady. I imagine temperature will cause a slight variation as well, but well within a set tolerance in a macro ?
RWC
Re: JOG Pendant
Postby cncdrive » Fri Apr 12, 2019 7:16 pm
From where did you get those values?
In the UCCNC the analog value is represented as a 16bit number (0-65535 values) for the 0-100% input range.
So, it has to be your macro who converts the values to the format you got in that file.
Temperature variation can cause a drift in the -40 to +125°C range, if I recall it is +-3 low significant bits maximum, but I can look it up in the microcontroller datasheet which has the AD converter built in...
Re: JOG Pendant
Postby Vmax549 » Fri Apr 12, 2019 7:43 pm
Those number are what UCCNC displays for teh analog input values . They are 16 bit values of teh voltage apparently.
I would have thought UCCNC would have displayed them in volt values seeing the input was in volts (0-5v). To get Voltage values divide that number by 13107 (65535/5v).
(;-) TP
Vmax549
Re: JOG Pendant
Postby RWC » Fri Apr 12, 2019 9:28 pm
cncdrive wrote:From where did you get those values?
Hi, those are displayed on the diagnostics screen, lower RIGHT corner.... and are updated regularly. At what preset frequency, I do not know. There is no macro necessary, it is "in there".
Russ
RWC
Re: JOG Pendant
Postby RWC » Fri Apr 12, 2019 9:38 pm
Vmax549 wrote:Those number are what UCCNC displays for teh analog input values . They are 16 bit values of teh voltage apparently.
(;-) TP
Thanks TP .
That comes out to "pert dang neer" rock solid !
I think I can trust that ...... thanks ;)
Might be able to come up with other uses for this.
In series with a momentary button, could greatly expand the I/O .... for other certain functions. :)
Russ
RWC
Re: JOG Pendant
Postby renotec » Tue Jul 14, 2020 6:31 pm
Is it possible someone give me step by step instruction to change port / pin M25020 & M25021 ?
My X, Y, Z, A (no B, C) selection port & pin are ;
X = port 5, pin 4
Y = port 5, pin 5
Z = port 5, pin6
A = port 5, pin7
I changed M25020 as follow but not working.
// =============== Inputs - Port, pin, negate
const int portMPGX = 5;
const int pinMPGX = 4;
const bool negMPGX = false;
const int portMPGY = 5;
const int pinMPGY = 5;
const bool negMPGY = false;
const int portMPGZ = 5;
const int pinMPGZ = 6;
const bool negMPGZ = false;
const int portMPGA = 5;
const int pinMPGA = 7;
const bool negMPGA = false;
const int portMPGB = 0;
const int pinMPGB = 0;
const bool negMPGB = false;
const int portMPGC = 0;
const int pinMPGC = 04;
const bool negMPGC = false;
Thank you in advance.
renotec
