Spindle Won't Start Using New Laptop!
Re: Spindle Won't Start Using New Laptop!
Postby Vmax549 » Tue Feb 28, 2023 8:25 pm
I am guessing the PC is 5v and the Laptops are 3v ?
Just a thought, (;-) TP
Vmax549
Postby wmgeorge » Tue Feb 28, 2023 9:25 pm
Are you in the UK or US?
wmgeorge
Postby wmgeorge » Tue Feb 28, 2023 9:27 pm
Vmax549 wrote:I am guessing the PC is 5v and the Laptops are 3v ?
Read the Thread that's been covered in detail.
wmgeorge
Postby mtrehy » Tue Feb 28, 2023 9:39 pm
wmgeorge wrote:Are you in the UK or US?
UK mate
mtrehy
Postby wmgeorge » Tue Feb 28, 2023 11:53 pm
UK mate
And the controller special box and PS? Picture and model number, thanks.
So it looks like your trying to drive a VFD Inverter to a feed a 3 phase spindle motor and you need the Input On signal which is not happing. Photos of the Inverter connections and model number please so we can see the entire picture.
wmgeorge
Postby mtrehy » Wed Mar 01, 2023 7:30 am
The *special " board is home made. You can see it on the left hand side of the 2nd picture on page 1 of this thread. The wiring diagram for it is also attached on that page
The 5v power to that boat does not come via usb as it is present when usb not connected.
The inverter is described as keb combivert but I can't get access to that presently as it's pushed against the wall. Should be able to at the weekend
mtrehy
Postby wmgeorge » Wed Mar 01, 2023 9:07 am
OK its 3 am our time March 1st, up to take a pain pill after my nasty fall on Ice... long story.
Anyway, I think your on to something with the VFD enable On-Off signal, and that relay click. So it may be looking for a dry contact closure or on-off voltage signal and it looses the common ground source to the VFD when you switch USB sources?
wmgeorge
Postby dezsoe » Wed Mar 01, 2023 9:59 am
Is the PW(5V) LED on when you try to use the machine? Without the 5V on the BOB the PWM signal will not be generated, it needs both 5V and 12(up to 24)V.
Postby mtrehy » Sun Mar 05, 2023 12:47 pm
Mystery remains unexplained but I bought a cheap all in one pc that I will use with a wireless mouse and keyboard and it works fine. So there must be some sort of a difference between the usb on all 4 of the laptops I have tried and the usb on a pc based machine.
mtrehy
Postby wmgeorge » Sun Mar 05, 2023 9:58 pm
mtrehy wrote:Mystery remains unexplained but I bought a cheap all in one pc that I will use with a wireless mouse and keyboard and it works fine. So there must be some sort of a difference between the usb on all 4 of the laptops I have tried and the usb on a pc based machine.
Excellent, and I am guessing as others it was the voltage/power at the laptop USB vs desktop. You said you had added a powered USB hub but it was not doing the job. These are the better ones > https://www.tomshardware.com/best-picks/best-usb-hubs
wmgeorge
Users browsing this forum: Bing [Bot] and 18 guests
