uc 100 problems
Re: uc 100 problems
Postby cousinit75 » Sun May 22, 2022 1:38 pm
charliem wrote:Ok go into the uccnc software and goto configuration/I/OSetup.
Then look and the eStop and make sure you the correct pin and port selected. Also either active high or active low check box.
Right, now the estop is behaving itself,the machine will not move the Z but will move the X and Y but only one direction regardless of what hotkey I have selected. I had this issue before but I cant find where I posted how I fixed it.
cousinit75
Re: uc 100 problems
Postby charliem » Sun May 22, 2022 6:26 pm
Ok so forget the hotkeys for now.
If jogging with the jog panel will your machine move as expected?
Regards
Charlie M
charliem
Re: uc 100 problems
Postby cousinit75 » Sun May 22, 2022 6:32 pm
charliem wrote:Ok so forget the hotkeys for now.
Thanks for the patience in trying to sort this, I reverted back to the chinese intructions that I had forgotten about (bought this over 10 years ago). And it was all down to the ports and pins being the right numbers. So have now got it all moving correctly, now just to fine tune it as best I can. I'm sure I will be back tho.
cousinit75
