by dezsoe » Sun Feb 02, 2020 10:37 am
Then I have no more idea. With setting the min. duty to 75%, UCCNC is correctly set up. You may have some cabling problem or the VFD not set up as it should. You should start with a switch and a potentiometer and test the VFD first, then replace the switch with the UCCNC driven relay and just after all, connect the analog out. Of course, when you disconnect the VFD, check the AXBB outputs too, but those will work, I tested them with your profile.
