1.2112 screenset
Re: 1.2112 screenset
Postby cncdrive » Wed Oct 09, 2019 2:23 pm
OK, thanks guys.
I still made some modifications, trying to soften up the fix as much as possible.
Can you please test the attached exe file for crash and also for slider moves if it crashes.
If this does not crash then it is good enough that I will leave it like this then. :)
UCCNC.zip
(1.64 MiB) Downloaded 657 times
Postby markcadcam » Wed Oct 09, 2019 2:59 pm
It worked fine for me. BTW, the Screen Set looks great!
markcadcam
Postby NikolayUA24 » Wed Oct 09, 2019 3:03 pm
cncdrive wrote:OK, thanks guys.
Works great. GIF file can be viewed by clicking on it.
I use Google Translator.
NikolayUA24
Postby cncdrive » Wed Oct 09, 2019 4:49 pm
Thank you Nikolay. Then this is the end of this debugging session, I will keep the code like it is now. :)
Postby NikolayUA24 » Wed Oct 09, 2019 5:42 pm
cncdrive wrote:Thank you Nikolay. Then this is the end of this debugging session, I will keep the code like it is now. :)
Let people work and enjoy :)
NikolayUA24
Postby jmac80 » Thu Oct 10, 2019 9:29 pm
Love the new screenset for 2019, Thanks for your work :D
jmac80
Postby Tweakie.CNC » Fri Oct 11, 2019 10:26 am
Just an observation by Spuds and myself…
If any, other than the lower left datum position is selected the running toolpath is not correctly displayed within the window.
This is really not important but I just thought I would mention it.
Tweakie.CNC
Postby Delco » Fri Oct 11, 2019 11:28 am
Im liking this new screenset but would like to make some simple changes like colouring some buttons to highlight them , are there any tutorials around showing the basics of how the screenset editor works.
Delco
Postby cncdrive » Fri Oct 11, 2019 10:47 pm
I've checked and really the origin coordinate data for the laser image is not OK on the display.
I have just fixed it. It will be fine in the next release.
Postby cncdrive » Fri Oct 11, 2019 10:48 pm
There's some info in the UCCNC/Documentation folder of your installation.
And also there is some info in the UCCNC users manual.
