1.2112 screenset
Re: 1.2112 screenset
Postby cncdrive » Mon Oct 07, 2019 12:40 pm
Andrew, the problem is that it would not fit in this design, because as you can see the tab selections are in the middle.
Postby NikolayUA24 » Mon Oct 07, 2019 1:10 pm
cncdrive wrote:Hi Nikolay,
Can you please test if you delete the slider from the jog screen and placing back that AS3jog.Setfieldtext("10", 913); then does it crash?
I would like to figure out if the slider causes this issue or the textfield itself.
It is unclear, because when the textfield gets the value that slider on the jog screen has the same labelnumber, so it also updates it's value.
And so far I do not see what could be the problem with that line of code, so it would help if you can tell me if it crashes without the slider, but with that Setfieldtext line put back in the screenset.
JOG FEED% + causes program to close :o
Row deleted
put back
Row deleted
I use Google Translator.
NikolayUA24
Postby cncdrive » Mon Oct 07, 2019 1:24 pm
Hi Nikolay,
I asked you to delete the slider, not the textfield please.
The slider is the red line which you can click to adjust the value on the jog screen.
It is the slider 913. on the jog screen.
Postby cncdrive » Mon Oct 07, 2019 1:27 pm
I've marked the slider control with a red oval on the attached picture.
Postby NikolayUA24 » Mon Oct 07, 2019 1:48 pm
I do not understand what needs to be removed
https://youtu.be/lEDmqJth7Jk
Here to delete?
NikolayUA24
Postby cncdrive » Mon Oct 07, 2019 2:11 pm
The slider should be deleted, this is the code:
//Add sliders to jog screen
AS3jog.Addslider(64, 259, 121, -65536, -5658199, 1, 100, false, true, 913, 1);
And the
//Add textfields to jog screen
should be placed back into the screenset. Also place back the 913. textfield into the screenset if you removed it.
What I will know from this is if the crash is cased by the textfield update or the slider update.
These are all complex codes, so it would narrow it down a lot for me if I would see if this crashes or not without the slider.
Postby NikolayUA24 » Mon Oct 07, 2019 2:25 pm
cncdrive wrote:The slider should be deleted, this is the code:
And the
deleted line AS3jog.Addslider(64, 259, 121, -65536, -5658199, 1, 100, false, true, 913, 1);
added a line AS3jog.Setfieldtext("10", 913);
everything works ok
NikolayUA24
Postby thegreatwaldo » Mon Oct 07, 2019 7:15 pm
Hi Balasz.
Thank you, I guess i'll have to design my own screenset.
Cheers.
Andrew
thegreatwaldo
Postby cncdrive » Mon Oct 07, 2019 7:42 pm
Nikolay,
I'm trying to figure out what the issue is all day long, but see no problem at all in the code. :(
So, I've made a new exe file. Could you please make the screenset file as the original, I mean the slider and also the addfieldtext is back, so it will crash,
but I've put a number of MessageBoxes into this exe and would like to know what do you see on them and it is also interesting to see at which point will is crash.
UCCNC.zip
(1.57 MiB) Downloaded 524 times
Postby Delco » Tue Oct 08, 2019 4:05 am
Liking the new screenset more and more now I have got used to it. very nice overhaul.
The probe button on the main screen , does it have a different function to the probe on the probe screen - seems to produce a different zero value ?
Would also be nice to have a save button on the probe settings screen that saves all the settings rather than having to exit the program , or at least save on exiting the probe screens.
I have also experienced a problem where the spindle doesnt automatically turn off on a toolchange , I need to manually turn spindle on then off to make it go off - I assume its something to do with the HYwin14 plugin ?
Delco
