start/stop motion when cutting curves
Re: start/stop motion when cutting curves
Postby jonathanmahnken » Mon Oct 16, 2023 8:32 pm
Thanks. The arc was drawn in vectric, so i don't know why I would need to convert my arc to an arc. I noticed that there is an arc tolerance setting in uccnc that is default set to .10. Im wondering if I need to adjust that to a much smaller tolerrance??
jonathanmahnken
Postby Battwell » Tue Oct 17, 2023 10:33 am
in vectric. click on the questionable curve.
select node edit . shortcut N on keyboard.
does the curve have hundreds of nodes or just a few per curve?
if loads-convert to curves.
if just a few- adjust your cv settings to a higher tolerance.
i had a rare job recenty that my cv settings were way too tight to run. adjusted and run sweet.
Postby jonathanmahnken » Wed Oct 18, 2023 5:21 pm
Thanks. would a CV tolerance of .02" be to small? The factory setting was .10"
jonathanmahnken
Postby dezsoe » Wed Oct 18, 2023 6:11 pm
The factory settings are in metric, so if you use inches then you have to convert them first:
Postby jonathanmahnken » Sat Oct 21, 2023 4:40 pm
Thanks this makes sense
jonathanmahnken
