Slave axis steps per unit
Re: Slave axis steps per unit
Postby ger21 » Fri Mar 24, 2023 12:18 pm
wmgeorge wrote:Thats .003 inch measured over 27.55 inches.
That .003 can be anywhere, and doesn't have to be spread out equally.
What he really requires is screw mapping, because just specifying different steps per inch doesn't identify where the error is.
Postby wmgeorge » Fri Mar 24, 2023 1:41 pm
He could have that much error in the ball screw pre-load adjustment? What is the manufacturing tolerance for what he is making?
https://www.machinedesign.com/motors-dr ... -the-myths
wmgeorge
Postby Doncis » Fri Mar 24, 2023 7:12 pm
Deviation amount doesn't matter, 0.01mm or 1mm. Fact is you cannot configure one of most important parameter (axis steps per unit) of cnc machine. Very sad.
Doncis
Postby wmgeorge » Fri Mar 24, 2023 7:43 pm
Maybe your issue is in your choice of Ball Screws and the calibration of those rather than trying to do a software fix?
How are you Homing this Axis? Do you have a Switch or what on each motor?
wmgeorge
Postby Doncis » Fri Mar 24, 2023 9:05 pm
This question is pointless..
Yes, maybe "dumb" DMG mori engineers also have issues with choice of ball screws, and trying to fix software..
https://youtu.be/Irsy3FTUEuE?t=43
Doncis
Postby Delco » Fri Mar 24, 2023 11:21 pm
Doncis wrote:Granite moving gantry machine, one axis with two DFU3210 ballcrews on both sides. Ballscrews may be not from same bath.
0.08mm diaviation per 700mm.
Compensate this deviation is not possible for now.
If being 0.011mm out on a 100mm circle then I suggest you buy better quality ballscrews that are matched
Delco
Users browsing this forum: Bing [Bot] and 46 guests
