spumco wrote:Are you using the Y-series (red) CL stepper drives?
If so, you're in for a treat with the software. StepperOnline don't have any sort of user manual or explanation/description of the parameters - although the critical one is pretty easy to figure out (position deviation alarm)
On a hunch, I tried just about every other chinese stepper manufacturer/re-seller's CL tuning software and nothing but the StepperOnline software would connect. So if you get frustrated don't waste your time with JLC, Leadshine, or any of the other vendors' software.
On the other hand, if you got the higher-end TS series I believe those are re-branded Leadshine's, so LS's software works with those. Just having a readable programming manual might be worth the upcharge.
For the 'production' mill I installed the TS series motors, but still have never used the tuning software. They worked so well that until I found my round circle problem I haven't had any complaint about them. I've done a number of stepper motor projects over the last 10+ years and these motors are by far the quietest steppers I've run across. In fact, for stepper motors they are actually pleasant to listen to.
For the current project mill (this is the same one I mentioned in the thread you responded to about the spindle motor driver, both mills are identical twins that I bought on sale a few years back) I was going to use the same motors, in fact I ordered a complete set of them and started to install them when I ran across a video by a guy that goes by the handle Clough42 who was reviewing this motor:
https://www.omc-stepperonline.com/nema- ... motor.htmlI decided to give these a try and that's what I'm working on now.
So anyway....to update this thread, this morning I removed both X and Y motors and replaced them with the open loop motors, and the result was a perfect circle. Amazingly perfect, in fact, for an old mill. So I'd call that conclusive, it's the motors for sure. I then re-installed the servo motors and ran the program which gave me an oval once again. Not as bad as I was getting with the CL steppers which was about plus/minus 0.005", instead I'm getting plus/minus 0.002", much better but still unacceptable. So the next step will be to dig in and find out how to tune these. I will likely be back with questions about that, but for now a big thanks for the help and pointers from all.
