I have the same probe and I can't figure out where to input the actual height dimension of the touch plate/thingy.
I've measured 19mm in height.
Everything else works fine and the bit stops and goes up once it touches it. The problem is uccnc doesn't guess the probe's dimensions of course and I end up having the bit crashing onto the spoilboard.
Can you guys help?
Thank you
