I have swapped out my spindle motor on a denford Orac lathe for a 750W AC servo with drive from ASDA
I was looking for a servo that matched roughly the AC motor that was being swapped out and also was of a similar frame size so that it could be fettled to fit the mounted bracket / holes of of the old motor being replaced which was a 1/2HP (0.37kW)
https://www.deltaacdrives.com/wp-conten ... Manual.pdf
I was looking for a servo drive I could just feed with 230V single phase and didn't need another power supply for, hence the ADSA-A2 was what I needed / wanted.
I came up lucky on one on ebay being sold complete never used with a sundry breakout board and all the associated wiring etc that has helped at the same time I was looking.
It is HTD 5M belt driven with a 2:1 ratio as the original motor had a listed spindle speed of 2000 rpm which I didn't want to exceed. (I could not see how they achieved that speed though from the old drive with the pulley ratio the old motor was running but who am I to question)
The servo is rated at 3000rpm and has a maximum speed of 5000rpm.
I used a couple of tapelock bushes for the tapelock HTD pulleys as I could get one to match the spindle size of the lathe to replace the old ribbed belt.
I've since added a hollowshaft spindle encoder to the lathe spindle to replace the optical index as I found one as a cheap option that fitted over the spindle.
One of these but with I think 1000ppr / 500ppr (I forget).
guess you've been through the denford forum for all the technical info: http://denfordata.com/bb//viewforum.php?f=33
