Uccnc spindle setup
Re: Uccnc spindle setup
Postby Battwell » Sat Jan 25, 2020 9:48 am
does analog voltage change with different speeds commanded. ie s 1000 to s 5000? enter in mdi to test
Postby Stock3000gt » Wed Jan 29, 2020 6:31 pm
No analog voltage doesn't change no matter what I set the speed at.
My settings are as follows.
Spindle page
PWM Freq-1000
PWM min duty- 0
PWM Max-100
M3 relay pin 2 port 1
spindle velocity min-18000
spindle velocity max- 24000
both pwn spindle and spindle relay output enabled are checked.
I/O setup page
only thing I have done is Spindle PWM -> analog ch. 1
Stock3000gt
Postby dezsoe » Wed Jan 29, 2020 6:55 pm
Please, upload your profile (.pro) file to check.
Postby Battwell » Thu Jan 30, 2020 12:21 am
Uc 100 doesn't have an analog channel so untick that.
Postby dezsoe » Thu Jan 30, 2020 7:03 am
What kind of UC100? It is AXBB-E. At least on the first photo. :)
(And if it was a UC100 then there won't be an option to seledt analog channel.)
Postby Stock3000gt » Thu Jan 30, 2020 8:57 am
It's a axbb-e. How do I pull the pro file
Stock3000gt
Postby dezsoe » Thu Jan 30, 2020 12:30 pm
Under the message box you find Upload attachment, press browse, select the .pro file, press Add the file.
Postby Stock3000gt » Thu Jan 30, 2020 5:11 pm
Is this pro file gotten from uccnc and were do I find it in uccnc. Never herd of a pro type file before.
Stock3000gt
Postby dezsoe » Thu Jan 30, 2020 7:04 pm
Yes, it is in the UCCNC\Profiles folder.
Postby Stock3000gt » Fri Jan 31, 2020 4:41 am
I will try when I get off work. Thank you so far for the help.
Stock3000gt
