dezsoe wrote:OK, that screenset is old, but you can make it work.
- Find and write down the values from the old profile in section [IOsetupsettings]: CurrentHiLopinnumber, CurrentHiLoportnumber and CurrentHiLopinnegate.
- Load the new UCCNC with the old screenset (where the settings are in the I/O settings, but you cannot use them) and start Edit screen on the General settings page.
- While pressing Shift key select the I/O setup page.
- Change the pin, port and active low: click on the field and change labelnumber/boxnumber as follows. Always click Apply settings in the screen editor window after you changed the number.
- Current hi/low pin (labelnumber): old 96, new 2606
- Current hi/low port (labelnumber): old 275, new 2612
- Current hi/low active low (boxnumber): old 60, new 347
- Select File tab in screen editor and press Save screenset.
Now you can set the values that you wrote down and save settings. It should work now.
Users browsing this forum: Bing [Bot], Google [Bot] and 28 guests
