Hod Do I ?
Re: Hod Do I ?
Postby beefy » Wed Oct 30, 2019 11:31 am
needleworks wrote:Thanks beefy, that is exactly what I am trying to do. As I have already homed the machine, the Z axis is at the top of it's travel, the only way the Z axis can go after that is down. All my values are correct for going to "Park 1" , the only thing I am trying to achieve is to change the order in which the axis move. For example, where it says in the Macro :-
double parkZ = 100;
double parkX = 0;
double parkY = 0;
can I simply change this order to this, where the Z axis will move last :-
double parkX = 0;
double parkY = 0;
double parkZ = 100;
I'm "almost" sure I had it running this way before but I just can't remember how I done it.
Ha ha, I can tell you've had zippo to do with programming.
No, "double parkZ = 100;" for example is a variable declaration, not a C# command, so the order of variable declaration does not affect anything.
"double" is the type of variable. "parkZ" is the variable name. " = 100" is giving the variable an initial value of 100. The semicolon terminates that C# statement.
Look at the stock standard M200 macro, and then look at this modified one I've just done. I've added a few extra comments to help you understand a little more. Note I've added a 4th variable declaration for "parkZ_finish", and to make things clearer I've renamed "parkZ" to "parkZ_start". Carefully read through the code and you may get some idea of what's happening.
If your Z home position is zero then make "parkZ_start" equal to zero. Basically, if Z is homed, nothing will happen because Z is already at that position, BUT..............imagine if you wanted to use PARK1 and you'd forgot to home. Automatically Z will travel first to zero (if that's your Z home position).
// Go to Park position 1 macro
double parkZ_start = 100;
double parkX = 0;
double parkY = 0;
double parkZ_finish = 0;
if(!exec.GetLED(56)||!exec.GetLED(57)||!exec.GetLED(58)) // If machine was not homed then it is unsafe to move in machine coordinates, stop here...
  MessageBox.Show("The machine was not yet homed, home the machine before run to parking position!");
  exec.Stop();
  return;
int originalmodalmode = exec.actualmodal; // remember the modal mode
while(exec.IsMoving()){}
// FIRST MOVE COMMAND - MOVE Z TO "parkZ" position
exec.Code("G00 G53 Z"+ parkZ_start); // Move Z up first to park1 Z position
// SECOND MOVE COMMAND - MOVE XY TO "parkX" and "parkY" co-ordinates
exec.Code("G00 G53 X" + parkX +" Y" + parkY); // Move to XY park1 position
// THIRD MOVE COMMAND - MOVE Z TO FINAL POSITION
exec.Code("G00 G53 Z"+ parkZ_finish); // Move Z position desired after XY moves
exec.Code("G" + originalmodalmode); // Set system back to the original distance mode
If you like the thought of having the power to change stuff like this (took me just a few minutes to modify that macro), then I recommend learning a bit of C programming. Once you get the basics of that, you can move onto C# but C alone will give you a lot of understanding of what's happening in macros. Seriously it puts a real evil grin on your face when you can do that stuff.
beefy
Re: Hod Do I ?
Postby needleworks » Wed Oct 30, 2019 11:40 am
No experience whatsoever mate :? I just managed to do a little in Mach3 but even that was sketchy to say the least.
Many thanks for your assistance though mate, much appreciated indeed.
needleworks
Re: Hod Do I ?
Postby needleworks » Fri Nov 01, 2019 8:33 am
Big Thanks to beefy for the help, I got a chance yesterday to use his modified macro and after adding my values I just clicked on "Park 1" and it done "exactly" what I wanted it to do :D :D :D
Once again mate, big thanks to you.
needleworks
Re: Hod Do I ?
Postby beefy » Fri Nov 01, 2019 10:54 am
Ha ha, happy to see you happy.
Would I be wrong in guessing you are an Aussie ??
Keith
beefy
Re: Hod Do I ?
Postby needleworks » Fri Nov 01, 2019 11:47 am
beefy wrote:Ha ha, happy to see you happy.
Keith
Scotiish I'm afraid :)
needleworks
Re: Hod Do I ?
Postby beefy » Fri Nov 01, 2019 10:30 pm
I'm originally from Newcastle area.
I worked with you guys off Aberdeen. Yous would say that because I'm not too far from the Scottish border, I'm half OK. I'd be describes as a Scotsman with his head bashed in :lol:
beefy
Re: Hod Do I ?
Postby doncraig » Tue Jan 14, 2020 12:12 pm
Sorry to raise this thread again but I am having a deal of trouble with the P1 and P2 buttons. I have loaded the macro that beefy posted and the machine still does what it wants.
I have a Stepcraft 420 V1 UCCNC and UC100 controller. I am very new to all this and need a lot of help.
Whatever I put into the macro the Z axis lowers until it hits the base, I have to hit the Estop to prevent it.
I feel very frustrated that when I try a fix that seems to work for someone it never seems to work for me.
Please help.
Don W
doncraig
Re: Hod Do I ?
Postby doncraig » Tue Jan 14, 2020 7:36 pm
Hi a newbie here needing some info.
I have tried to use the macro that beefy posted but when I press the P1 (or P2) the Z axis just lowers until it jams on the base. Where have I gone wrong ??
Any help please.
Don W
doncraig
Re: Hod Do I ?
Postby doncraig » Fri Jan 24, 2020 7:56 pm
I received a fix from Rory. Thanks again.
Don W
doncraig
Re: Hod Do I ?
Postby albert2NB » Tue Mar 03, 2020 1:48 pm
Please help.
I'm facing the same issues right now. Did you fix it somehow?
albert2NB
