reset z to zero
Re: reset z to zero
Postby asuratman » Sun Jun 10, 2018 8:57 am
Hello,
Actually, I just want the torch to get surface as zero point like probing. After probing, then retract to a certain height maybe 2" above surface to ignite the torch. Then after all, sheetcam will handle the program to cut. I assume that the surface is flat. It will be good if there is program to probe and to save some point coordinate in case surface not flat. I don't use solenoids or valves. The valves are only on the torch to open and close gases. I only know to operate but do not know how to make program for machine, that's all I know.
asuratman
Re: reset z to zero
Postby Robertspark » Sun Jun 10, 2018 9:21 am
Once the torch is adjusted, how do you switch from preheat to cut?
On a hand torch using the cutting torch oxygen lever?
Re: reset z to zero
Postby Robertspark » Sun Jun 10, 2018 9:24 am
Look at the schematic here
http://neuroncnc.com/products/005
Re: reset z to zero
Postby asuratman » Sun Jun 10, 2018 10:27 am
Hello,
I do not use the one on neuron. I just want simple one.
[url]Once the torch is adjusted, how do you switch from preheat to cut?
On a hand torch using the cutting torch oxygen lever?[/url]
I use machine torch G31, not a hand torch. Open and close valve on the torch to control gas oxy/acethylene.
asuratman
Re: reset z to zero
Postby Robertspark » Sun Jun 10, 2018 12:27 pm
M0
(Light torch >> press "start")
G0 Zxxx (drop to pierce height)
G4 Pxxx (wait for pierce time delay)
G0 Zxxx (drop to cut height)
.... Continue with cut motion (X&Y)
Re: reset z to zero
Postby asuratman » Sun Jun 10, 2018 1:49 pm
Hello,
So first thing to do is to edit post processor on sheetcam as follow :
function OnPenDown()
post.Text (" M777\n") -- touch off Macro
end
Then after the torch found the surface and retract to 5" above material followed by :
M0
Start sheetcam with following constant, as follow :
I will find constant for pierce height, pierce time delay, cut height.
I will install my z axis and try this matter.
asuratman
Re: reset z to zero
Postby Robertspark » Sun Jun 10, 2018 1:57 pm
I am out at present (no pc)
I will create you a post processor to do all of this for you
Re: reset z to zero
Postby asuratman » Sun Jun 10, 2018 2:14 pm
Hello Rob,
Thanks in advance.
asuratman
Re: reset z to zero
Postby Robertspark » Thu Jun 14, 2018 10:55 pm
asuratman
I've added a simple post processor here for you to have a look at and use if you wish.
viewtopic.php?f=16&t=1313
It "may" be possible for you to use the "autoleveler" plugin to do what the PCB guys do to level their bed so that your machine will correct for the plate across the bed if you do not have THC {poor mans leveling hack}
https://www.youtube.com/watch?v=4bYjMY67ERY
Re: reset z to zero
Postby asuratman » Sat Jun 16, 2018 4:04 am
Hello Rob,
Thanks for the macro, I am now installing my floating-head z axis and oxy torch. I will try soon ...
asuratman
Users browsing this forum: No registered users and 30 guests
