Edge Probing and
Edge Probing and
Postby X3msnake » Mon Dec 18, 2017 5:08 pm
Greetings
I have a Stepcraft Probe
I am trying to use it to probe the edges of a work in order to compensate for any angle diference on the work placement on the jig
I see UCCNC does not support plane rotation how can I do this then, What am I missing?
Best regards
X3msnake
Re: Edge Probing and
Postby cncdrive » Mon Dec 18, 2017 9:35 pm
The UCCNC does support plane rotation on the XY plane, it is the G68 and G69 codes.
Postby X3msnake » Wed Dec 20, 2017 1:07 pm
Ok
Is there a roadmap to implement this in a near future?
What other solution can be used to rotate the toolpaths (maybe a plugin)?
Is there a good tutorial on how to integrate other softwares with a plugin for the UCCNC
I know of a open source software that would be able to do this G-Code Ripper, my knowlage in programming is basic but i think i could cook up a plugin if i can learn how the plugin implementation works...
X3msnake
Postby ger21 » Wed Dec 20, 2017 1:15 pm
G68 is already implemented. You'd just need to write a macro to do your edge probing and do the rotation.
Postby cncdrive » Wed Dec 20, 2017 1:39 pm
As I said rotation is already implemented, so there is no roadmap, because the software already supports toolpath rotation.
There are C# and VB plugin templates which install with the UCCNC into the Plugins/Examples folder.
Postby X3msnake » Wed Dec 20, 2017 11:50 pm
Sorry i misread as not implemented.
My bad
X3msnake
Users browsing this forum: bhdavis and 47 guests
