Safety door check
Safety door check
Postby odino87 » Thu Nov 28, 2024 10:40 am
Hi to every one
I was wonder if there is a way to implement a safety door check.
I have a lock security lock relay that I can energize with a switch to open the door, and there is a couple of pin that let me know if the security door is locked or not.
Is there a way to prevent UCCNC to start the job when the door is open?
And I want to prevent the user to open the door while the machine is on working too.
Do I have to implement a macro loop of some sort to do that?
odino87
Re: Safety door check
Postby cncdrive » Fri Nov 29, 2024 5:53 pm
Yes, in a macroloop you can make the UCCNC to call the .Stop(); function if that door open signal is active.
You could also use the faultsignals plugin.
