due to a loss of connection to the computer, I've needed to run from a specific line in the code. This shouldn't be a problem as I can use the "start from here" function.
This works, however it appears that the software moves to the previous line coordinates and goes from there.
The problem is it does this at mega-slow speed. Probably something like 1mm/min or so.
Question : where can I change this in the settings ? I found Safe height, which I changed to 10mm to reduce the distance to be moved at safe speed. But I'd prefer to change the safe speed.
