Hi, I'm thinking about adding a laser to my router. I'm struggling to find informations on the forum and don't specially know where to start ... I want too use this laser to cut corrugated cardboard to make boxes. I have a AXBB.
Where do I need to connect the laser on the board ? and do I need to use a different profil on UCCNC to seperate the spindle from the laser ? (thinking about M3 command)
Does the UCCNC post processor for fusion360 is set for lasers ?
I have done a test with the jet mode of Fusion360 and a tool referred as a laser there is 2 toolpath, one for the cutting and one for the etching but in the Gcode (attached) there is no variation of the "M10Qxxx" it only outputs the laser percentage selected in the post options, in this case, Q64 (25%)
thank for your help
