Mill and Laser
Mill and Laser
Postby CADdy » Sun Mar 12, 2023 10:00 am
Hi all,
I am using UCCNC with a UC400ETH controller for my milling machine. I am currently setting up a CO2 laser unit and would like to use UCCNC and a UC400ETH controller for that as well. How does this work best installation wise? I imagine two independent software installations in different directories with the respective license file. Would this be ok?
Peter
CADdy
Re: Mill and Laser
Postby dezsoe » Sun Mar 12, 2023 1:31 pm
Just create a new profile. There's no reason to run a different copy of UCCNC, the profile has all the settings you need.
Re: Mill and Laser
Postby CADdy » Mon Mar 13, 2023 2:47 pm
Thank you dezsoe for your info. That means, I will copy both license files into C:\UCCNC and start UCCNC with different profiles.
Peter
CADdy
Re: Mill and Laser
Postby CADdy » Mon Mar 13, 2023 4:35 pm
How does UCCNC know which controller is the right one? I can't find any relationship to the controller in the profile.pro. Is it possible to add a parameter (IP-address, serialnumber, etc.)?
Peter
CADdy
Re: Mill and Laser
Postby dezsoe » Tue Mar 14, 2023 9:48 am
Yes, it's in the manual. :) Create a shortcut on your desktop. (Rigth click UCCNC.exe, send to, desktop.) Rename the shortcut as you need. Now right click the shortcut, select properties. Go to the end of the line, after e.g. C:\UCCNC\UCCNC.exe and change to "C:\UCCNC\UCCNC.exe /p yourprofilename /s serial", without quotes, but spaces between the switches and their parameters. This will start UCCNC with the given profile and serial number.
Re: Mill and Laser
Postby CADdy » Tue Mar 14, 2023 4:09 pm
Hi dezsoe,
now that you mention it, I found it too. Thanks for the hint ;)
Peter
CADdy
Users browsing this forum: Bing [Bot] and 39 guests
