Good afternoon guys.
I have some questions about connecting delta b2 step dir signals to axbb.
I would like to use the linear method.
Because if you connect through an open collector, the pulse frequency will be only 200 kHz.
Is it possible to connect for example positive signals (37, 41), as in the photo, to non-isolated outputs (O9-O17 on Axbb), and put negative ones (39, 43) into 5V0?
I don't really want to use isolated outputs (O2-O8) for open collector connection.
Also, can I connect the fourth axis in a linear way using the outputs O1-O9 on Ucsb?
I was going to put positive signals on them and minus signals at 5V0 on Axbb.
Thank you in advance
