muzzlitebeer wrote:Yeah, but... you've still got to wrap your head around how Linux works. Even the basics are a challenge.
But yeah, there is a huge cohort of LinuxCNC users out there, and they're mostly EXTREMELY helpful. My brain just isn't wired for Linux.
At least I already know how to do things in Windoze.
Ha ha, yeah, can't argue with that.
I think half the problem with Linuxcnc learning is that you need to know a little about Linux itself BEFOREHAND.
I mean here's something from the beginning of the Getting Started manual:
LinuxCNC requires a kernel modified for realtime use to control real machine hardware. It can, however run on a standard kernel
in simulation mode for purposes such as checking G-code, testing config files and learning the system. To work with these kernel
versions there are two versions of LinuxCNC distributed. The package names are "linuxcnc" and "linuxcnc-uspace"
The realtime kernel options are preempt-rt, RTAI and Xenomai. ...............................................And:
Xenomai is also supported, but you will have to find or build the kernel and compile LinuxCNC from source to utilise it.
I mean WTF.
The instructions seem to assume you already understand some of the basics of the Linux operating system, but for someone coming from Windows who is not a nerdy type:
What the hell is the kernel.
What the hell is a package.
What the hell is compiling from source.
Etc, etc, the list goes on.
Whoever has wrote the instruction manual probably knows Linux and Linuxcnc backwards but does not consider how it appears to someone from Windows, especially basic users. No wonder many are scared away from Linuxcnc, even the beginning of the Getting Started manual will be double dutch to windows users.
I've been typing in commands such as "sudo apt-get install............" etc, but only been doing what I've been told to without having a clue what any of them mean, and it does make you rather uncomfortable.
I've started looking into Linux tutorials in order to start making sense of many of the command line instructions. It all starts to make sense then LOL.
The UCCNC install is definitely much simpler.
