Probing Q's
Probing Q's
Postby Archy » Mon Sep 13, 2021 2:41 pm
Is there a way to probe x, then y but wait for a prompt asking you to rotate a v bit? For a corner alu probe plate. I have to rotate the v bit to it's widest.
I can't seem to override the probe bit diameter, I set it to 15 but it keeps saying in the main probe window that it's 10.
Also probing Z didn't seem to set the zero point to the probe plate thickness I set? It set the zero to exactly the height of the z plate.
Archy
Re: Probing Q's
Postby dezsoe » Mon Sep 13, 2021 2:46 pm
If you use the probe screen then it all works. Use the Pause before probe switch to pause before probe. On the setup page you can enter the diameter to override the tool table, but you also have to check the Override probe dia checkbox. If you enter the gage height the turn on the Axis 1 count gage switch to use the value.
Users browsing this forum: Bing [Bot] and 22 guests
