Probing - must be doing something wrong
Re: Probing - must be doing something wrong
Postby AxelKay » Fri May 21, 2021 6:49 am
I have the same probe and I can't figure out where to input the actual height dimension of the touch plate/thingy.
I've measured 19mm in height.
Everything else works fine and the bit stops and goes up once it touches it. The problem is uccnc doesn't guess the probe's dimensions of course and I end up having the bit crashing onto the spoilboard.
Can you guys help?
Thank you
AxelKay
Postby dezsoe » Mon May 24, 2021 7:21 pm
Do you use the Probe button which calls the M31 macro or the Start probing button on the probe screen?
Users browsing this forum: No registered users and 30 guests
